‎08-27-2020 02:02 AM
We are having a flow in Flow Designer which needs to be run 'Daily'. We gave the trigger condition as 'Daily'.
This flow is used to fetch data from a third party tool.
And we would want this to be 'Run As' a specific user which we have created in the user table.
But the only option I am finding is 'Run As' - User who initiates the session.
Like how we have an option in 'Scheduled Data Import' to select the specific user.
Is the same possible in Flow Designer ?
Flow Designer
IntegrationHub
‎08-31-2020 07:35 AM
In Flow designer if you choose the Trigger as Daily, Weekly, Monthly and activated,there will be a scheduled job created automatically in the back end with name starting 'Trigger:<sys_id of flow>'.
So you can simply create the flow from Flow designer as you want.
And then go to Scheduled jobs and update 'Run As' field.
Thank you
Venkat
‎08-27-2020 05:34 AM
Thank you for the approach.
We were also thinking in the same .
But then we figured that Scheduled Job also doesn't seem to have 'Run As' option.
Got it confused with 'Scheduled Data Import'.
‎08-27-2020 05:55 AM
Thanks Deepen. It worked.
Does that mean the trigger condition which we give in Flow Designer will be overridden by the Scheduled Job in every case ?
‎08-27-2020 06:50 AM
No i don't think it will override but both will work. And without Trigger it wont allow to activate the flow hence we gave something which will work for us.
‎08-27-2020 07:42 AM
I personally feel using both Flow Designer + Schedule job to achieve this requirement would lead to more code maintenance.
Schedule job to trigger flow and then flow actually doing the task.
As suggested you can raise a enhancement request or explore on the feature from Paris release
‎08-27-2020 07:47 AM
Yes. Agreeing to the point.
