Run Flow Executionwith ATF
OMT
Giga Guru
I should run a Flow Execution for the incident to check whether an SMS has been sent. Is it possible with ATF to run the flow to trigger the sending of SMSs?
3 ACCEPTED SOLUTIONS
Ankur Bawiskar
@OMT
flow runs in background and is server side logic and can't be checked with ATF.
Please close the thread buddy.
OMT
Giga Guru
closed, buddy 😄
11 REPLIES 11
thank you mate 🙂
OMT
Giga Guru
closed, buddy 😄
Philippe Casidy
With ATF you can create the conditions to trigger the flow and then you can validate that what triggers the SMS has been generated with the correct content.
Hi, how can i achieve that please?  What are the test steps?
