‎03-03-2022 11:10 PM
Hi everyone,
How do you set approval in workflow?
I would like to set the approver to be from variable?
the catalog item variable is manager and value will be from manager field.
Thanks in advanced.
Service Catalog
Service Portal
Workflow
‎03-07-2022 11:22 PM
If this workflow is on request then you should query the RITM details and use them
somethink like this.
var answer=[];
var grScReqItem = new GlideRecord('sc_req_item');
grScReqItem.addEncodedQuery("request="+current.sys_id+"^cat_item=1391a4db070630100b36f6fd7c1ed0c2");//map you catalog item sysid here.
grScReqItem.query();
if (grScReqItem.next()) {
answer.push(grScReqItem.variables.manager.toString());
for below line you should modify the highlated part with the catalog item sysid you want to fetch manager details from.
‎03-04-2022 12:13 AM
@Freddy
Create Approval User activity and try below code in advanced script:
answer=[];
answer.push(current.variables.u_manager.toString()); //give your manager variable name
Hope it helps
Murthy
‎03-07-2022 10:36 PM
Hi Murthy, , this doesn't seem to work. Do you have another idea?
‎03-07-2022 10:41 PM
Hi Freddy,
Can you share the scrrenshot?
‎03-07-2022 10:50 PM
Please replace with gr with current
‎03-07-2022 10:58 PM
Hi Murthy,
thanks for the response.
Variable name on order guide is manager
this variable = manager is part of a variable set.
I just changed to gr.variables.manager.toString() or current.variables.manager.toString()
Both don't work.
answer = [];
answer.push(current.variables.manager.toString());
