Unable to capture Flow Designer flows in update set -- facing issue with flow version reference
LakshyaG8207824
I have my source instance where I had setup all my custom flows, custom subflows, custom actions and some custom tables and fields. However, I had recorded all of those in the Default Global update set. Later, I moved all the records in the default update set after 10 Oct 2025 to a newly created update set, exported the new update set and imported it into the target instance. However, I get a lot of errors after I preview the update. All of them have the same error message: "Could not find a record in sys_hub_flow_version for column version_record referenced in this update "
Why weren't the version records captured in the update set? What can I do about it?
Robson Leite
I faced the same issue. As a Workaround I force the expected records from sys_hub_flow_version into my Update Set. As a final fix, in my understanding, this table should be captured automatically via Update Set (Adding the update_sync Attribute in Dictionary application).
11 REPLIES 11
Robson Leite
This is the solution that worked for me
