What scenario would create Two duplicate Knowledge articles with same number?
barbclark
Mega Expert
I have a user who some how has created two draft Knowledge articles with the same number.       In what scenario could this happen?
I have already deleted the duplicate , so I don't think an incident is necessary and we cannot reproduce.           This has only happened once so far as I know.
I appreciate all of the responses.       I am going to keep an eye on this.
That script could work. Just a note that this will need to be updated for the kb_knowledge table.
Nevertheless, this feels more like a workaround than an actual solution. In the newer UI's, the double-clicking should be prevented as an overlay will appear on the form and form bar as soon as the user clicks on a UI Action. If this is the case (where a user double-clicked) then this would definitely need to be investigated.
Barbara,
I have raised an Incident with ServiceNow Technical Support to investigate this issue with you.
Kind regards
Shahid
That's perfectly understandable, Barbara. If you run into this issue again you can follow up on the INT and we will dig into it.
I had the same issue on our instance too. Deleting the duplicate KB number is a quick fix. It would be nice if there is a prevention solution.
