I'm not able to use "Right Click and select Configure" option from the form
12-17-2025 11:04 PM
I’m unable to use the “Right-click → Configure” option on the form for the sn_customerservice_case table, even though I have the admin role.
My objective is to modify the form layout, but the system does not display the form configuration or design options when I right-click on the form.
When I attempted to add the sn_customerservice_case role to my user profile, the system threw an error stating that customer roles can only be added if the user has the sn_internal role.
Given this restriction, could you please advise on the correct roles or approach required to customize the form layout for the Customer Service Case table?
12-17-2025 11:13 PM
@Sathwik1 , please check the view of the form that you are trying to edit .
Also check the current application scope if it is same as that is used for CSM form application scope.
12-17-2025 11:16 PM
seems your form is broken and hence right click on form not allowing
check browser console and see the error
some client script or UI policy is causing this error
12-18-2025 01:40 AM
12-17-2025 11:30 PM
Hello @Sathwik1 ,
As @Ankur Bawiskar mentioned this seems to because of broken form. as I faced similar issue while configuring form on case records. So, check recent activities of form or related UI configurations.
Siddhesh Gawade
