Modify specific system properties in my Script Include invoked by various business rules
DaQQF
How to restrict modifications to specific system properties when coding this logic in a Script Include of my scoped application. Note that this Script Include is invoked by various business rules or ACLs and executes regardless of which user triggers those rules.
  • System properties are stored in the sys_property table; modifying them via scripts typically uses gs.setProperty() or direct GlideRecord updates.
To avoid confusion, it’s important to distinguish "Write roles" from the related "Read roles" field in sys_property:
Field Purpose
Write rolesControls who can modify the property (edit value, delete the record).
Read rolesControls who can view the property (if left empty, all users can read it).
Example Use Case
If you set the "Write roles" of a scoped app’s property (e.g., x_your_app.api_key) to x_your_app.admin, only users with the x_your_app.admin role can update that API key. Regular users or even system admins (without the scoped admin role) will be unable to edit it—preventing accidental or unauthorized changes.
0 REPLIES 0
