ACL error when using Configure function field for reports
Mike_G5
I am receiving the following error when trying to use the "Configure function field" option available in the new UI Report Designer:
"Access to this content denied based on report_view field ACLs."
The report source is sc_task table.  The report works without any errors if the "Configure function field" is not used.
I have reviewed the report_view ACL's for the sc_task table and did not see any conditions that should prevent access.
I am using the Configure function field to calculate the duration of a task being opened then closed.
Any idea how to determine what is causing this error?
See Attachments:
11 REPLIES 11
Elena Mata
Did you manage to make this work? I have the same issue with incident table, I have other configure function field in other reports, that work perfectly, but not for the incident table. I've create ACL for the function field, and even then is not working, and always report same error
jayaram4
Hey,
I followed the below product documentation link and it's working as expected.
LINK: ACL control of function fields (servicenow.com)
Jayaram Reddy JOOLAKALVA
