Flow Designer Create a Flow course - What is it asking us to do in the Test your work part?
jeremyduffy
In Activity 2: Add Flow Logic, there's a Test your work section
First it tells you to view it in Flow Diagramming mode, then this:
It says to go to platform view, but I forgot the names. By process of elimination, I have to assume that the regular view is platform view, but I don't see anything called "Social Media Management". What does it mean "module" anyway? Is that a section of the flow? Where would we see test records be?
I thought maybe it meant the application explorer, but I don't see anything that would be "Social Media Managmeent > Monitor" as described. I can click Social Media Management in the left menu or I can click Monitor, but there are multiple instances of each:
What am I supposed to do here?
J Siva
Hi @jeremyduffy
Currently you are inside the studio. Below are the platform views.
In the filter navigator search "Social Media Management".
Siva
Dr Atul - LNG
Hi @jeremyduffy
It is referring to the Application Navigator. I don't have it set up, so it's not available for me.
J Siva
Hi @jeremyduffy
Siva
So that's the "Platform view"? Sheesh. Either way, your answer makes sense for what they're asking. Thank you!
