Need Help with Platform Analytics Task Validation
MrKen
Hi all,
I’m working on the Platform Analytics Task, but it keeps failing validation despite multiple attempts. I’ve carefully followed the task instructions and recreated the dashboard and chart to match the example image at the end of the task.
The validation error I’m receiving is:
“Was a Pie Chart report created from the Priority field of all active incidents? Was there a new title for this report and was it saved?”
I can confirm that the answer to both is yes. My dashboard and chart look identical to the example, yet the task still fails. I’ve attached a screenshot showing both the dashboard/chart and the validation error.
Has anyone else run into this issue or found a solution? Any suggestions would be greatly appreciated.
Thanks in advance for your help!
Bhuvan
Giga Patron
@MrKen
Click on information icon of dashboard and change the chart title as per instructions 'Open Incidents by Priority'. In your dashboard, it is currently 'Incident Overview', change it accordingly. Save the dashboard and validate it.
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
21 REPLIES 21
SandhyaR
Incase you are wondering about where to locate the "Details" tab, pls click on "Edit in Designer" and you will see the "Details" i icon on the right tab as below. Updating this below helped validate the task successfully
OmaO
Mega Contributor
Thank you.
This worked for me
EdvardK
This worked for me as well.
PrajithM
Task is failing with error "Was a Pie Chart report created from the Priority field of all active incidents? Was there a new titl..."
The post activity screen appears same as required in task.
need some help.
LisbethR
Giga Contributor
Hey, I am also having the same issue.
Change the name from Incident Overview to Open Incident by Priority, in hopes but same outcome.
