ServiceNow advance reference qualifier
shivani18
My Advance reference qualifier for
"Caller field in Incident will show users of only department of logged in user" not working
9 REPLIES 9
Hello @AakashG2703 ,
Thank you for replying
i made the script include client callable
but still it is not working.
is there any issue in my script?
Hi @shivani18,
Request you to try to create a new "Script Include" as "Client Callable". Pls do not modify an existing one. There is a reason that I personally seen many times behind to not to modify an "existing Script Include" as it does not get updated as per the "Checkbox Selection or De-Selection".
If you find any information/knowledge/solution helpful, please don't forget to mark my solution and reply as helpful and accepted.
Thanks ‌‌:)
Aakash Garg
ServiceNow Developer
hello @AakashG2703 ,
no its still not working.
may be there is some issue in my script's query
can you please check once again
Hi @shivani18,
Hope you are doing well.
Proposed Solution
I tried again to rectify your issue on my "Personal Developer Instance" so that you can get the solution as soon as possible. As a solution, I started looking into your script and implemented it on my PDI and started debugging it by adding lot of "System Logs" and here are some findings that I found mentioned below: -
  1. Replace getDisplayValue() --> getValue() in Line 8.
  2. Replace addEncodedQuery() --> addQuery() in Line 9.
Attaching Screenshot for the reference: -
New Script: -
var PopulateUsersBasedonDepartment = Class.create();
PopulateUsersBasedonDepartment.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    loggedInUser: function() {
        var logged_user = gs.getUser().getRecord();
        var depart = logged_user.getValue('department');
        gr.addQuery('department', depart);
        var callerUser = [];
        while (gr.next()) {
            callerUser.push(gr.getValue('sys_id'));
        return 'sys_idIN' + callerUser;
    type: 'PopulateUsersBasedonDepartment'
It seems to be working fine for me. Hope this time your issue gets resolved.
If you find any of the shared information/knowledge/solution helpful, please don't forget to mark my solution and reply as helpful and accepted.
Thanks ‌‌:)
Aakash Garg
Subhashis Ratna
Hi @shivani18
I have updated Code for SI ....
//Logic - 1
    var loggedUserRec = gs.getUser().getRecord();
    var depart = loggedUserRec.getValue('department');
    var grRec = new GlideRecord('sys_user');
    grRec.addQuery('department', depart);
    grRec.query();
    while (grRec.next()) {
        callerUser.push(grRec.getValue('sys_id'));
    return 'sys_idIN' + callerUser.join(',');
Logic - 2
        var depart = gs.getUser().getDepartment();
        var userGr = new GlideRecord('sys_user');
        userGr.addQuery('department', depart);
        userGr.query();
        while (userGr.next()) {
            callerUser.push(userGr.getValue('sys_id'));
        return callerUser;
SS - 1
If this solution resolves your query, kindly mark it as the accepted solution and give it a thumbs up.
Subhashis Ratna
