How to disable virtual agent sound alerts
Yasmin
Does anyone have information on how to disable the sounds in virtual agent? Everytime a message comes in there is a sound. Business would like to have the ability to disable it. There used to be info on this in the release notes but not anymore.
Thanks!
Muralidharan BS
Hi Yasmin,
If its for single user then you can try - Settings > Notification > connect > Turn off audio
Muralidharan BS
Hi Yasmin,
