Diagram Flow not displaying anything
JLeong
Hi Guys,
First, the Diagram Flow was grayed out because of the following error:
So I removed the Error Handler, and then it let me toggle between the 2 views, however the Diagram is empty:
Am I missing anything?
Thank you!
JLeong
Yes, this issue is fixed in Washington!!!
12 REPLIES 12
Maurice Murphy
After speaking with Now Support, they let me know that this is related to a known problem in Vancouver (PRB1723237).
I will say that I faced this issue before we upgraded to Vancouver (if memory serves I've had it since Tokyo, at minimum), but they've provided a workaround via KB1585758, and stated it will be fixed in the Washington, D.C. release. I ran their provided script and am now able to get the diagram toggle to work again.
Here's the script from the KB (linked above):
// IMPORTANT: Run script in scope: sn_diagram_builder
var gr = new GlideRecord('sn_diagram_builder_node_type_handler');
gr.get('369c7d0b77b470104f27ceec8e5a9912');
while (gr.next()) {
    gr.deleteRecord();
That solved the problem! I checked that my Washington PDI doesn't have the record as expected, so it's probably solved on that version already as they said
JLeong
Adam43
interesting, my Vancouver Patch 8 instance- it does not work and Washington patch1 hotfix2 it does work.
when i compare the record that script deletes on the sn_diagram_builder_node_type_handler table- the xml's are exactly, 100% the same. so it must be included in VancouverPatch8.  but yet still doesn't work for me......
I say that- because when I try running the script in scripts background- I get the following error and it won't delete that record
Security restricted: Delete operation against 'sn_diagram_builder_node_type_handler' from scope 'rhino.global' has been refused due to the table's cross-scope access policy
This error is probably happening because you're trying to run a script that's on a scoped application. I had the same problem and the easier route I found was to export the record XML, edit the active field to false, and upload it again to my instance, so instead of deleting I deactivated it which has the same effect
