‎12-07-2023 10:58 PM
I have built a flow designer that copies all the attachments from RITM to task.
The catalog item and workflow belongs to a custom scope, I am using the below following three steps to copy attachment:
- Look up RITM attachment record in sys_attachment table, to fetch list of sys ID's.
- Running a for each loop on above action to fetch the comma separated sys IDs one at a time.
- Using Copy Attachment action to copy attachment from source to target record, which is task.
I understand that its not an issue with this logic because I am able to make it work in Dev instance. When I promoted it to TEST instance for UAT, its causing issues there, by throwing the error as :
Error: undefined is not a function.,Detail: undefined is not a function.
Initially there was a cross scope issue, where read privilege was missing for sys_attachment table. I later provided that, but its still not working in Test.
Troubleshooting done:
- Inactive and re-active the flow in test.
- Recapturing and pushing the update set back from Dev to Test after providing Cross scope Read privilege in Test.
- Creating a flow from scratch in Test just to test if it works with the new flow.
Nothings seems to be working, kindly help.
‎12-08-2023 12:10 AM
you are saying it's working in dev but not in test. Did you check everything got captured and migrated to test?
‎12-08-2023 06:12 AM
The issue got fixed, it was an issue with cross scope permissions.
‎02-16-2026 09:09 AM
Since the original author did not detail the issue they had with Cross Scope permissions.... if your Flow is running in a Scoped App, you may need to set up Cross-Scope Application Access for a couple APIs used by the OOTB Copy Attachment flow action. For me I needed to add two, with the following settings:
- Source Scope: [Your App Scope]
- Target Scope: Global
- Target Type: Script Include
- Target Name:
- 1. AttachmentActionsUtil
- 2. AttachmentActionErrorHandler
- Operation: Execute API
- Status: Allowed
