Flow - For Each - "Error: Invalid assignment left-hand side."
04-03-2024 01:01 PM - edited 04-03-2024 01:04 PM
Hoping someone can give me advice on an error I'm getting in a Flow, in a For Each loop. (This is in Utah.)
The concept is simple. It's a catalog item request trigger. One of the variables is an employee number value. The Look Up Records action uses this and searches the user table.
If more than one user is found, a For Each loop is needed to determine certain things about each of those user records. Problem is the For Each loop itself is just erroring out like this. Doesn't make any sense to me and I can't see anything wrong. Searching Gulag gives me very few hits, and none relevant enough to be useful.
Any advice would be appreciated. Thank you!
Flow Designer
04-09-2024 06:03 AM
As requested. 🙂
04-09-2024 01:09 PM
Thanks @apjohn2,
Configuration-wise, everything looks correct, and even tested it in my PDI which is working fine.
A few things to try/note:
- Try a different employee number to fetch records
- Delete and re-create the Action or test with a new Flow
- In Action #8, shouldn't it be 'is greater than or is 1'? Also does 'anzahl' mean the same thing as count? Couldn't help but notice it in the screenshot
- What is the scope of the Flow?
Cheers
