How to configure Flow designer wait for condition based on work notes and state
Harrys09
Hi ,
Hi, in flow designer I have created a wait for condition based on a catalog task record I would like this wait for condition to only execute if the state is closed complete or if the work notes contains the string ‘ready to begin’ and i needed help please with creating a script for this in the wait for condition?
thank you
win b
Mega Guru
Hi @Harrys09 ,
Theres already a wait condition form the catalog Task on Flow Designer. You need to indicate from the following Conditions from the IF Statement you may validate on this. on the IF Flow logic. and add in the condition based from the Data Picker on the right.
Inside the if is where you should insert the task and check on the wait checkbox its an indication or equivalent to wait condition
