How to validate RITMs in Order Guide Based on their State
win b
Mega Guru
Hi There,
Can someone help me on this. I know this is easy task but im a little bit confused and i dont know were to start at. So basically i have an Order Guide Setup and from that i declared 3 Catalog in my Order Guide. Then on my REQ here is the following i needed.
When the REQ is created it will generate 3 RITMs based on the 3 catalogs i put in the Order Guide (Catalog1, Catalog2, Catalog3). Then i created  WF and implement it to my Order Guide (which is i dont know if this is working) and from that WF i created a checker for each RITMs if there is a Closed Complete, Closed Incomplete, Closed Skipped RITMs states, and from that point this will be my checker.
1 Closed Complete & 2 Closed Incomplete = REQ Closed Incomplete
2 Closed Complete & 1 Closed Incomplete = REQ Closed Incomplete
1 Closed Complete & 2 Closed Skipped = REQ Closed Complete
2 Closed Complete & 1 Closed Skipped = REQ Closed Complete
3 Closed Complete = REQ Closed Complete
3 Closed Incomplete = REQ Closed Incomplete
3 Closed Skipped = REQ Closed Complete
1 Closed Complete & 1 Closed Incomplete & 1 Closed Skipped = REQ Closed Incomplete
Sumanth16
Mega Patron
Hi @win b ,
Please refer to below thread:
https://www.servicenow.com/community/developer-forum/update-req-based-on-ritm-state-and-stage/m-p/26...
If I could help you with your Query then, please hit the Thumb Icon and mark it as Correct !!
Thanks & Regards,
Sumanth Meda
@Sumanth16
The table in BR should be in SC_REQUEST or in SC_REQ_ITEM?
Hi @win b ,
Create after business rule on RITM table
Thanks & Regards,
Sumanth Meda
@Sumanth16
i tried the following and its not working.
winb_0-1709615714268.pngwinb_1-1709615723379.pngwinb_2-1709615742453.pngwinb_3-1709615784479.png
