Change Management , Release Management and DevOps (Gitlab spoke)
xjxx
Hello Everybody,
In regard to Change Management and Release module are they two separate processes within servicenow, that someone can raise change request, while decide to raise a release or are they integrated (meaning I can invoke a release from the change flow and come back to the change after certain phase of the release and so on ?
The second part is about DevOps, can I integrate the DevOps Action with the change and release modules ? such as invoke deploy of release to production from Gitlab after the release been developed, change approved and schedule time of deployment reached ? then come back to close the release and change enter post implementation review ?
Hi @Dr Atul - LNG
Thank you very much.
So the ability to link the change management and release management is possible through the flow design, but its not there by default ?
For the Digital Product Release, is this a replacement for Release Manaement Module.v2 ? or they will work together?
* For me if it can have a flow and integrated with change management, other DevOps pipelines, and ITSM ticketing and be customized then its better to have it as a replacement for the Release Module instead of having multiple modules that are overlapping.
Thanks.
Hi @xjxx
Atul: In Release we can add the change and vice versa.
Atul: My knowledge say, it is replacement of Release V2.0
I strongly recommend, get DPR in your PDI and attend this session.
