compare old values and new values in flow designer
mariavic1998
Hello everyone, I wanted to know if you have any idea of how to approach this condition in flow designer, I think there's some scripting needed but I'm not sure. the conditional is the following one:
and this is all I have until now:
CMDB Whisperer
The only direct access you have to the previous value is from within a Business Rule, not a flow.  The flow is something that runs asynchronously, after a record has already been updated, so the previous value is no longer available to the program/flow logic.  So you are best off accomplishing this logic in a Business Rule.
That said, if you absolutely need to do this from a flow after the update is already made, you may be able to pass the values to an Event that could then trigger a Flow.
The opinions expressed here are the opinions of the author.
Aman Kumar S
Hi @mariavic1998
Flows runs asynchronously, you will not be able to extract data for previous, you will have to use BRs for that.
Best Regards
Aman Kumar
