How to manually register Stacked Switches in CMDB
Martina M
Hi there,
Could you please navigate me an help me what is the best practise for Stacked switches registration? When we have one master switch and several slave switches? We do not use Discovery on Network devices and we do the registration manually. Currently we have it as one CI with multiple Serial Numbers which represents master and slave switches. Does any Class exist where we can mark it as Stack and  master and slave? And also what kind of relation would you use between them?
Thanks a lot!
12 REPLIES 12
Martina M
Thnak you. That's exactly what I am searching for.
SK Chand Basha
Tera Sage
Tera Sage
Hi @ctsmith
How the stacked switched getting discovered , with single ip address how the OOB solution is working, i have checked the Shared library in IP Switch pattern.
Well... it didn't work with OOB solution for us.  We did a network discovery job that ran against a range of IPs that our switches lived on.
