Same cataloge Items call multiple items within one order guide. is it possible
varsharani gaur
Can you give any example
What kind of example do you need? If you use flow designer to run on creation of one RITM, you can get the variables (OOB flow action). Then you can use a 'for each' logic to create a RITM for each of the contacts.
Mark
Hi @varsharani gaur ,
As others also have stated, I would recommend that you create the additional RITM through Flow Designer pr. best practice.
Best regards
Anders
Rising star 2024
MVP 2025
An order guide is multiple catalogue items in a single request bundle. It will be Helpful to include an image and your usecase, with your why? Also some catalogue items may be for a mobile view or are prior versions and are inactive. Review your rule configuration and the catalogue items and flows.
