How can we create Problem Task automatically when problem record is moved to Root cause analysis state?
Shikha puri
Solution Plan Problem Task type to be created automatically when problem record is moved to Root cause analysis state except for when problem priority is 5-Planning and to auto populate the values of the problem records like assignment group, priority, short description and description-Solution plan task ,type -solution plan, due date - 30 days ahead of problem created date.
Please help.
Example below
32 REPLIES 32
But I want to create a task automatically when problem record is moved to Root cause analysis.
Hi ,
You can create a Business Rule then ,
and give condition After -> update
filter condition ->
State Changes to Root Cause
Then do Scripting.
Pls Mark Helpful or correct.
Akanksha Gupta
will you provide me that script also ?
Or shall we also create the workflow for the same ?
Ankur Bawiskar
@Shikha puri
Please use flow designer with no script.
Just add 1 more condition to what Thomas has mentioned
In the flow trigger
Priority [IS NOT] 5-Planning
Also link the problem task with the problem by using the problem field
HI Ankur,
Is that below mentioned workflow correct ?
Created on Problem table.
Please check and help me to create the correct workflow for the same.
