‎10-02-2025 11:35 PM
Requirement:
I need to configure a System Notification for the Incident table with the following logic:
If Assignment Group = Test Group and Assigned To = Abel Tutor
Then the notification should be sent to all members of "Test Group" except the assigned user (Abel Tutor).
What I Tried:
Created a notification record in sys_notification.
Defined the trigger conditions.
Added notification content in the Related List → Content → Next Experience (Subject + Body).
Tried defining receiver logic using an email script inside the Next Experience content.
Challenge:
The receiver logic is not working as expected — the notification is not being sent to the intended group members.
‎10-04-2025 02:55 AM
Hi @Ankur Bawiskar ,
Thanks again for your response and support.
Observation:
Case 1: In my official instance, when I add Assignment Group in the Who will receive tab, no bell notification goes to any user of the group. However, when I try the same in my PDI (Yokohama version), the bell notification goes to all users of the assignment group.
Case 2: In my official instance, when I add Assigned To in the Who will receive tab, the bell notification goes correctly to that user.
Conclusion:
It seems this may be either a platform/version issue (Official instance = Xanadu, PDI = Yokohama) or some configuration difference between the two environments.
Solution Implemented:
I changed my approach and found a working solution:
Created a new Event.
Added a Business Rule with logic to exclude the Assigned To user, and stored the sys_ids of all remaining users in the Assignment Group into a comma-separated array.
Triggered the event in the Business Rule.
Linked the event to a sys_notification record.
Created a Next Experience content record for the notification body.
This approach worked successfully in my official instance.
‎10-03-2025 12:29 AM
check my below response.
‎10-02-2025 11:52 PM
If you are talking about Provider Notifications then you can configure the Recipients
Simply select the field Assignment Group and don't select Assigned to
But I think it will send notification to Assigned to user as well as that user will be member of that group.
‎10-03-2025 04:30 AM
Thanks @Ankur Bawiskar ,
But this is not as per the requirement.
‎10-03-2025 05:00 AM
so please share screenshots.
‎10-03-2025 05:06 AM
Below i requirement.
If Assignment Group = Test Group and if Assigned To = Abel Tutor
