Need help in UI page for 'g:ui_reference_multi' usage
Divya P
I am trying to set the dynamic 'query' for a reference field (g:ui_reference_multi).
The query is set based on the value of the other field but I can't get it to work.
HTML Script:
Initially I have set the Query as below :
<g:ui_reference_multi id="multi" name="multi" table="sys_choice" query="name=u_hiring_plan_availability_hours^element=u_month" coloumns="label" onChange="onMonthChange(e)"/>
Client Script:
I am trying to show Months based on the year selected :
function getMonths(response) {
var mnthsArr = JSON.parse(answer);
alert(mnthsArr);
var userArray = [];
//all the members of the selected group
var gmAud = new GlideRecord('sys_choice');
gmAud.addQuery('name', 'u_hiring_plan_availability_hours');
gmAud.addQuery('element', 'u_month');
gmAud.addQuery('value', mnthsArr[0]);
gmAud.query();
while (gmAud.next()) {
if (userArray.indexOf(gmAud.sys_id.toString()) == -1)
userArray.push(gmAud.sys_id.toString());
alert(userArray.toString());
var YearLookUp = gel('multi'); //document.getElementById("multi") //gel('lookup.multi');
YearLookUp.setAttribute('query','sys_idSTARTSWITHb8a29bf8db65fc109f9b6f8bd3961985');
Can anyone help me to set the query in client script based on change of other field
@Divya P
can you try this?
var YearLookUp = gel('lookup.multi'); //document.getElementById("multi") //gel('lookup.multi');
YearLookUp.setAttribute('onclick',"mousePositionSave(event); reflistOpen( 'multi', 'not', 'sys_choice', '', 'false','QUERY:inactive=false','sys_idIN" + userArray+ "', '')");
Divya P
@Ankur Bawiskar I am not using  g:ui_referene ui macro since I am using  g:ui_reference_multi ui macro below is not working
Tushar
 I hope this helps -
<g:ui_reference_multi id="multi" name="multi" table="sys_choice" reference="sys_choice" columns="label" onchange="onMonthChange()"/>
Client Script -
function onMonthChange() {
  var answer = g_form.getValue('your_other_field'); // Replace 'your_other_field' with the actual field name that holds the value to be used for the query
  var userArray = [];
  // Query the 'sys_choice' table on the client-side to get the sys_ids for the months based on the selected date
  gmAud.query();
    if (userArray.indexOf(gmAud.sys_id.toString()) === -1)
  // Get the reference field element
  var referenceField = document.getElementById('multi');
  // Set the reference attribute on the g:ui_reference_multi macro with the dynamic query
  referenceField.setAttribute('reference', 'sys_choice'); // Set the table name for the reference field
  referenceField.setAttribute('query', "active=true^sys_idIN" + userArray.join(',')); // Set the dynamic query based on the selected date
Please, don't forget to mark my answer as correct if it solves your issue or mark it as helpful if it is relevant for you!
Tushar
