Need help with Parallel approval in flow design
Sohini Kar
I need help with Parallel approval in flow design.
Requirement:
Create a request to provide access to folder path.
Suppose we are asking for access for 4 different path, It will go for 4 different approval.
If 1 is rejected. That path should go to different variable name: Rejected folder
and for rest 3, task should be created.
How can I achieve this with Flow designer.
In my case it is going for approval one by one. And if 1 is rejected then whole RITM is becoming closed incomplete.
Sohini Kar
I have fixed the issue in an easier way.
Instead of "Ask for approval", I simply updated record in "Approval table"
No coding was needed and approvals were generated for each folder path.
J Siva
Hi @Sohini Kar
Parallel approval cannot be achieved using a single flow. To implement this, you need to create parent and child catalog items along with corresponding flows.
Below is the community response I provided for a similar requirement. PFB
https://www.servicenow.com/community/developer-forum/servicenow-flow-designer-approvals/m-p/3207671/...
Let me know if you have any queries.
Siva
Hi, It wont work as the number of approval is not limited.
The approval is coming from a List collector Variable. So user can add as many path as they want from the table, and for each path, each approval will go.
I got a similar workflow script. But I am unable to write the similar workflow script in Flow design.
Here is the script:
var util = new FNC_MassFileDirectoryUtil();
var folder = JSON.parse(current.variables.mass_folder_selection);
var folderArray = [];
folder.forEach(function(fd) {
    folderArray.push(fd.folder);
workflow.scratchpad.approvalMap = util.createApprovals(folderArray, current.sys_id.toString());
I do not know the work around of Workflow.scratchpad. I am new in flowdesign
Ankur Bawiskar
@Sohini Kar
parallel approvals are always challenging in flow, but here is the workaround. it uses Do the following in Parallel
Parallel Approvals in Flow Designer
sharing 1 more link
Parallel approvals in flow designer - proposed solution
Here is the script:
