Only Problem Manager should be able to create Problem Tasks
VijayshankaK
 I have a  requirement that only Problem Managers should be able to create problem tasks
I tried Controlling Through List Control  giving Problem_manager role under New Role without omitting New Button
This is not working there is one OOB ACL - itil role required to create problem_task records
I have updated the role with Problem_manager by removing ITIL and problem_task _analyst then also i can see ITIL User is able to create problem tasks
Please assist me on this
@problemmgmt @Atul Gupta @itsm @ACL @LIst Control
@VijayshankaK
Hope you are doing good.
13 REPLIES 13
Rohit  Singh
Hi @VijayshankaK ,
Please make sure to check all  Problem.none and Operation = Create ACL's and make modification accordingly.
Also check if problem_manager is inherited in ITIL role.
If my response helped, please hit the Thumb Icon and accept the solution so that it benefits future readers.
Rohit
VijayshankaK
@Rohit Singh  yes its inherited how to deal with it without touching OOB
Hi @VijayshankaK ,
I would also suggest the same which is already suggested by @Ankur Bawiskar to have group created use script section of ACL to identify specific group.
Rohit
Nishant8
Tera Sage
Hello @VijayshankaK , If you just want to restrict users, except problem manager, to create problem task from list control then can you change the script of 'Omit new condition' as below and then try?
if (new ProblemTaskStateUtilsSNC().canCreateProblemTask(parent) && gs.getUser().hasRole('problem_manager'))
    answer = false;
else
    answer = true;
