09-15-2025 04:30 AM
Sources box(right side ) , Please provide the steps on how to configure it to show that box.
03-17-2026 11:12 AM
Solution - It's updated feature and page has updated in new version , it won't show as previously . Most of fresh instance it will not show but for previous(before XANADU or other recent version before , may be).
09-15-2025 06:51 AM - edited 09-15-2025 07:02 AM
Hi @jaiho_rai
The Sources box is OOB , but if you don’t see it, the page may not contain the widget by default.
You can check it by doing the following:
Go to Service Portal Configuration and click on Designer.
In the search bar, type the page ID you want to check, for example: sw_search .
Open the page from the results.
If it’s missing, you can add the widget manually to the container you want, then Save & Publish.
Thanks & Regards,
Muhammad Iftikhar
If my response helped, please mark it as the accepted solution so others can benefit as well.
Muhammad Iftikhar
09-16-2025 05:15 AM
What is the widget name for the source?
03-17-2026 11:12 AM
