need help in incident management.
Nafisa Zaman
Hi all,
I have a requirement to populate the following fields on the incident form:-
1. In a incident form when a field is checked the choices in section will populate in service now.
2. In a incident form when a field is checked  capture the time in a time filed for any reporting purposes.
3.If a incident state is closed  the choices in section automatically set to be close.
4.if anyone tries to set an incident to resolved while Field  status is open , then throw a message stating "Filed is active , please confirm from team"
Any help will be appreciated.
AniketC85155510
Hello @Nafisa Zaman ,
For the requirements you've listed, most of them can be achieved through client scripts or UI policies:
1. Populate choices in a section when a field is checked:
You can use either an onChange or onLoad client script depending on when you need the choices to be populated. For example, in an onChange client script, you could use:
if (newValue == true) {
g_form.setSectionDisplay('<section_name>', true);
Replace `<section_name>` with the actual name of your section.
2. Capture time in a field when a checkbox is selected:
You can use the following code in an onChange client script to capture the current date and time and store it in a specific field:
    var today_date = new Date();
    var today_date_time_str = formatDate(today_date, g_user_date_time_format);
    g_form.setValue('time_field', today_date_time_str);
  • Replace 'time_field' with the ID of the field where you want to store the date and time.
  • This will ensure the current date and time is formatted based on the user’s locale settings.
3. Automatically set choices to "Close" when the incident state is closed:
Use an onChange client script to update the choices when the state is set to "Closed":
if (newValue == 'Closed') {
g_form.setValue('choices_field', 'Close');
Replace `'choices_field'` with the field where you need to set the choice.
4. Restrict resolution while Field Status is active:
Use an onSubmit client script to check the field status. If it’s active, display an error and prevent submission:
if (g_form.getValue('field_status') == 'Active' && g_form.getValue('incident_state') == 'Resolved') {
g_form.addErrorMessage('Field is active, please confirm from the team.');
return false;
Replace `'field_status'` and `'incident_state'` with the appropriate field names.
Please Mark ✅Correct if this solves your query and also mark 👍Helpful if you find my response worthy based on the impact.
Aniket
Sid_Takali
HI @Nafisa Zaman I suggest you to create a UI Policy as a Best Practice
1. Create onChange client script on Checkbox field. use below code
if(newValue == true){
OR
2. you can Create a UI Policy on Condition CheckBox_field is True
Use below code in True Condition in Run Script
Use below code in False Condition in Run Script
g_form.setSectionDisplay('<section_name>', false)
Sid_Takali
Hi @Nafisa Zaman  To capture the time in a time field, You can write a after Insert/Update Business rule
if(current.checkbox_field_name.changesTo(true))
              current.time_field_name = gs.nowDateTime();
AniketC85155510
return false;
Aniket
