Instance Help
raaaaam
Hi ,
It looks like my instance is down, can anyone help me on this ?@
1,325 REPLIES 1,325
Unfortunatly instance help is no longer monitored by servicenow. you can create a case
But its better to release instance and request for a new one if you don't have important data
Mark Helpful if it helps.
***Mark Correct or Helpful if it helps.***
How do I create a case?
Joshua14
Hi, My instance is down can someone help me? Its been on 'Restarting Instance' these past two days. dev76406.
gopal sabavath
My instance is https://dev29164.service-now.com is down can someone help? it's been restarting instance since past one month
