Instance Help
‎04-21-2017 11:51 AM
Hi ,
It looks like my instance is down, can anyone help me on this ?@
- 251,770 Views
‎08-25-2022 04:44 AM
Hi @Yousaf
Is there any way that can restore the data from our old instance and have it moved into new instance?
Thanks in advance
‎08-11-2022 05:39 PM
My instance won't come out of hibernation. While I can relate, I would appreciate someone's help in rousing it.
‎08-11-2022 06:03 PM
Hi Rachel,
This is a known issue these days. Unfortunatly no one will be able to help here. Instance help is no longer monitor by servicenow
Options we had before are not available anymore like "Give feedback" button
Now the best thing to do is release you instance and request for a new one if you don't have important data.
or create a case.
Mark Correct or Helpful if it helps
***Mark Correct or Helpful if it helps.***
‎08-12-2022 03:51 AM
My instance is not waking up - dev93124 - can you please assist?
‎08-15-2022 06:09 AM
My instance is not waking up, been like this for days, waited for no luck. Can someone help?
