Instance Help
raaaaam
Hi ,
It looks like my instance is down, can anyone help me on this ?@
1,325 REPLIES 1,325
Prem96
My PDI suddenly went offline, and now won't wake.  All I get from the developer site is the message "The instance is offline. Please check again in a few minutes."  .... this has been like this now for over an hour.
Instance is:  https://dev122058.service-now.com/
raghu432
Hello All,
All of a sudden since this morning my PDI dev113701 won't wake up and is this something across all the PDI's....?
Kunal Varkhede
Hello Team,
My Instance is offline. Can someone please help. dev52159.
Please check the below screenshot.
Kunal
James Lewis
I need help with my Offline instance. Dev82623.
J
Hi @James Lewis,
Instance being in offline mode is an ongoing issue for some time now. Unfortunately, Instance support is no longer provided by ServiceNow. We no longer have feedback button also.
Note: For any urgent work, Best you can do now is to release the instance and request for new one if you don't have important data. You can get a new instance in less than 5 min.
As per the impact and if its not PDI (customer/partner instance), you can raise HI case for this issue. For PDI, ServiceNow no longer provides any support.
Mark this as Correct/Helpful if above info. helps in any way and help in closing this thread.
Shubham
