Instance Help
‎04-21-2017 11:51 AM
Hi ,
It looks like my instance is down, can anyone help me on this ?@
- 251,777 Views
‎08-17-2022 12:58 PM
My instance is also not coming online, it has been a few hours, is there planned maintenance today, or is anyone able to assist me?
dev61371
‎08-17-2022 08:51 PM
‎08-17-2022 09:14 PM
I have the same issue. But this forum is no longer monitored. And feedback option is also no longer visible. Seems like the only option is to request a new PDI. I am gonna lose all my work. What a mess.
‎08-18-2022 02:15 AM
hello my instance is offline what should I do
‎08-18-2022 02:28 AM
Hi
Instance being in offline mode is an ongoing issue for some time now. Unfortunately, Instance support is no longer provided by ServiceNow. We no longer have feedback button also.
Note: For any urgent work, Best you can do now is to release the instance and request for new one if you don't have important data. You can get a new instance in less than 5 min.
As per the impact and if its not PDI (customer/partner instance), you can raise HI case for this issue. For PDI, ServiceNow no longer provides any support.
Mark this as Correct/Helpful if above info. helps in any way.
Shubham
