Instance Help
raaaaam
Hi ,
It looks like my instance is down, can anyone help me on this ?@
1,325 REPLIES 1,325
ShubhamGarg
Just to get this thread and let community know about the current, updated and correct solution to this PDI issue, I am commenting below info. Please mark this as CORRECT ANSWER if you think it is appropriate to end this thread and post.
Instance being in offline mode is an ongoing issue for some time now. Unfortunately, Instance support is no longer provided by ServiceNow. We no longer have feedback button also.
Note: For any urgent work, Best you can do now is to release the instance and request for new one if you don't have important data. You can get a new instance in less than 5 minutes.
As per the impact and if its not PDI (customer/partner instance), you can raise HI case for this issue. For PDI, ServiceNow no longer provides any support.
Shubham
Muhammad Awais1
My personal instance https://dev77855.service-now.com/ can't wake up from hibernation.
Please advise thanks!
Muhammad Awais1
Hi, My Instance is offline for a long time can you please look into this. Thanks in advance.
YZ X
Kilo Explorer
Hi, My instance stays in restarting stage for more than 8 hours. Could you please help to take a look? dev58389
Raviteja Kunal1
my instance https://dev86386.service-now.com/ is down and stats is restarting. Can you please check on this.
