Instance Help
‎04-21-2017 11:51 AM
Hi ,
It looks like my instance is down, can anyone help me on this ?@
- 251,918 Views
‎04-24-2023 02:28 PM
Hello, it's been a couple weeks and I still can't get my instance up. I get "Developer Instance is undergoing unscheduled maintenance. Get Notified when your PDI is available."
‎04-26-2023 01:58 AM
Hi Mike,
Greetings!!
It is a very common issues now a days. Instead of waiting , please get a new instance.
Mark my answer helpful if it serve the purpose.
Atul G
‎04-25-2023 01:18 AM
Hi, my instance dev167037 is hibernating and it doesn't wake up. I also have this "App Engine Studio is not installed on this instance. You can install App Engine Studio by activating the plugins on your instance" and I don't have any option available to activate a plugin. Only options available are Release Instance or Refresh Instance. Thank you!
‎04-26-2023 02:00 AM
Hi Mate,
Seems it stuck. Did you try to get the plugin from store? If did not work, then only option either reset or release the instance.
Hi Mike,
Greetings!!
Atul G
