Instance Help
‎04-21-2017 11:51 AM
Hi ,
It looks like my instance is down, can anyone help me on this ?@
- 252,007 Views
‎03-03-2024 07:58 AM
Hi @User728374
1. There is no support available for PDI.
2. If you can wait, more, let's wait
3. You may release this instance and take a new one but in this case, you will lose your previous data.
‎03-04-2024 05:17 AM
requested new instance today. upon logging in for first time. language was displaying in Japanese. with the help of google translate I was able to check system properties and found that the default system language was correctly set to English. I then check the user properties of the sys admin account and found that its language field had a value set to what assumed is the code for Japanese. open changing it to System default(English) and reloading, I now see that half of the selections in the filter navigator are in English but some are still in Japanese. Why was the instance loaded with the Japanese language plugin? why was the sys admin set to use this plugin? Why am I still seeing Japanese? I could release and get another instance, but I think someone needs to look into this. dev176207
‎03-04-2024 06:11 AM
I released the instance above and requested a "new" one. when I logged in for the first time I was in the csm/fsm workspace. this too is clearly not a new PDI. dev59962 .
‎03-04-2024 06:37 AM
I released dev59962 and requested another new one. Got another used one.
I guess PDIs are broken.
‎03-04-2024 06:22 AM
My instance is also offline for last 4 days dev228565
