Instance Help
raaaaam
Hi ,
It looks like my instance is down, can anyone help me on this ?@
1,332 REPLIES 1,332
@Kamini Kansal
My developer instance is showing offline for the last 3 days.
https://dev106907.service-now.com/
As14
Kilo Explorer
my instance is not waking anymore.
Can you help?
Tnx
Kamini Kansal
Hi As,
Your developer instance is currently offline due to a datacenter maintenance in progress. Once work has completed, your instance will be online and ready for use.
Unfortunately, we do not have any ETA. We are actively working on this issue. If you have a backup of your instance like update sets or on git, you may release this instance and get a new one.
We apologize for any inconvenience caused.
Kamini Kansal
Fosi
My instance was offline for more than a week now (https://dev92196.service-now.com/) . can you help me out pls
Hi Fosi,
Go here https://developer.servicenow.com/ , login with your credentials and click on wake instance.
Hope it helps you.
Thanks and Regards,
Shivanand
