Instance Help
Joshua Camacho
My PDI instance will not wake up. Can someone please assist? Thank you
Dr Atul G- LNG
Hi @Joshua Camacho
Here are some points to consider:
  1. There is no support available for PDI.
  2. If you can wait, let's wait a bit longer.
  3. You can release this instance and start a new one, but you will lose your previous data. To avoid losing update sets in the future, make sure to take regular backups of your PDI.
There have been 3-4 posts in the community today about PDI failures or unavailability. Based on the responses, you might need to wait 1-2 days and hopefully, the PDI will be back online.
AndersBGS
Hi @Joshua Camacho ,
As you might know, there is no support available from ServiceNow in relation to PDI, hence you're limited to two options:
  1. Wait, it should come online after some time.
  2. If you get tired of waiting, release your instance and request a fresh installation. Please notice, all development work that hasn't been backup will be lost for good.
Best regards
Anders
Rising star 2024
MVP 2025
