instance help
Options
06-24-2025 05:44 AM
Hi ,
It looks like my instance is down, can anyone help me on this ?@
Options
06-24-2025 05:45 AM
Here are some points to consider:
- There is no support available for PDI.
- If you can wait, let's wait a bit longer.
- You can release this instance and start a new one, but you will lose your previous data. To avoid losing update sets in the future, make sure to take regular backups of your PDI.
There have been 3-4 posts in the community today about PDI failures or unavailability. Based on the responses, you might need to wait 1-2 days and hopefully, the PDI will be back online.
Options
06-24-2025 12:50 PM
As you might know, there is no support available from ServiceNow in relation to PDIs, hence you're limited to two options:
- Wait, it should come online after some time
- If you get tired of waiting, release your instance and request a fresh installation. Please notice, if doing so, all development that hasn't been backed up will be lost for good.
