Need help with my PDI instance: not waking up
danamato
Need help with my PDI instance: The past few days I cannot Wake up or Refresh the instance.
thanks!
Dr Atul - LNG
Hi @danamato
I've been using PDI without any issues since this morning, but I've noticed several posts in the community about PDI being offline. Here are some points to consider:
  1. There is no support available for PDI.
  2. If you can wait, let's wait a bit longer.
  3. You can release this instance and start a new one, but you will lose your previous data. To avoid losing update sets in the future, make sure to take regular backups of your PDI.
There have been 3-4 posts in the community today about PDI failures or unavailability. Based on the responses, you might need to wait 1-2 days and hopefully, the PDI will be back online.
Backup and restore you PDI data using GITHUB
FYI, earlier Backup and restore feature was available for PDI's which is disccontinued since 15 DEC 2022
Link to that Post- https://developer.servicenow.com/blog.do?p=/
Dr Atul - LNG
Hi @danamato
