07-23-2024 04:19 AM
When setting up Task Intelligence, as the final step I am asked to setup recommended actions. Does anyone know whether the Incident context and recommended actions should appear OOB pre-configured? I can't see any at when using the OOB setup.
Is there any guidance on setting this up or importing a pre-configured version?
Thanks.
Task Intelligence
07-23-2024 08:48 AM
I figured out that the plugin ‘Service Operations Workspace ITSM Applications’ was missing and is required to setup recommended actions. Will continue and revert back if there are any issues.
Thanks.
07-23-2024 08:48 AM
Thanks.
07-26-2024 05:27 AM - edited 07-26-2024 05:28 AM
Good to hear Chaz, that makes sense. Sorry I assumed you had all the plugins for Service Ops Workspace installed as that is where you access Task Intelligence. Glad you figured it out! -lener
02-12-2025 10:25 AM
Thank you for posting this. I am testing Task Intelligence, having issues and the Service Operations workspace needed an update.
