Attachment mandatory not working in Serviceportal
salu
Mega Guru
Hello All,
I am trying to make attachment mandatory in catalog item and service portal. Below script working in catalog item but not working in serviceportal.
We are using Add to cart button in service portal.
function onSubmit() {
//Works in non-portal ui
try {
var attachments = document.getElementById('header_attachment_list_label');
if (attachments.style.visibility == 'hidden' || attachments.style.display == 'none') {
alert('You must attach the completed form before submitting this request.');
return false;
//For Service Portal
catch (e) {
var count = getSCAttachmentCount();
if (count <= 0) {
return false;
Can some please help??
Saranya
Ankur Bawiskar
@salu
Refer blog below
Verify Mandatory Attachments Count on Catalog Item
Sharing the steps and script here
Script: onSubmit
UI Type - ALL
Applies to Catalog Item - True
Note: Ensure Isolate Script field is set to False for this Catalog Client Script to ensure DOM manipulation works
var countRequired = 1;
	if(window == null){
		// portal
		if(this.document.getElementsByClassName('get-attachment').length != countRequired) {
			return false;
	else{
		// native view
         var length = $j("li.attachment_list_items").find("span").length;
		if(length != countRequired){
			return false;
Isolate Script: Set to False
21 REPLIES 21
I would suggest to not use any script for portal .
Updated client script and set UI Type as "Desktop"
return false;
For Portal , open your catalog form and set "Mandatory Attachment" as true .
I don't want the whole catalog item for attachment mandatory. When ever user need access request,then add manager approval like.
I need a confirm message if the user "Is this request a Access request?" If yes attachment is mandatory if no then able to submit the form
Got it. Did you follow the same step which has mentioned in below thread. Please confirm,
Browser console error indicating you missed something in script, either UI Scripts or some method . Please check the below thread and confirm .
https://community.servicenow.com/community?id=community_question&sys_id=de340b29dbd8dbc01dcaf3231f96...
You are right.This is the error.
I am not able to find any script include with this name
This is UI Scripts method name.
