12-03-2020 05:46 AM
Hello All,
I am trying to make attachment mandatory in catalog item and service portal. Below script working in catalog item but not working in serviceportal.
We are using Add to cart button in service portal.
function onSubmit() {
//Works in non-portal ui
try {
var attachments = document.getElementById('header_attachment_list_label');
if (attachments.style.visibility == 'hidden' || attachments.style.display == 'none') {
alert('You must attach the completed form before submitting this request.');
return false;
//For Service Portal
catch (e) {
var count = getSCAttachmentCount();
if (count <= 0) {
return false;
Can some please help??
Saranya
12-03-2020 07:13 AM
Refer blog below
Verify Mandatory Attachments Count on Catalog Item
Sharing the steps and script here
Script: onSubmit
UI Type - ALL
Applies to Catalog Item - True
Note: Ensure Isolate Script field is set to False for this Catalog Client Script to ensure DOM manipulation works
var countRequired = 1;
if(window == null){
// portal
if(this.document.getElementsByClassName('get-attachment').length != countRequired) {
return false;
else{
// native view
var length = $j("li.attachment_list_items").find("span").length;
if(length != countRequired){
return false;
Isolate Script: Set to False
12-03-2020 07:15 AM
UI Script:
API Name:GlobalCatalogItemFunctions
Script:
function getSCAttachmentCount() {
var length;
try {
length = angular.element("#sc_cat_item").scope().attachments.length;
} catch(e) {
length = -1;
return length;
onSubmit Catalog Client Script:
var contract = g_form.getValue('signed_pricing_contract');
if(contract == 'Yes'){
try { //Works in non-portal ui
if (attachments.style.visibility == 'hidden' || attachments.style.display == 'none' ) {
alert('Please attach atleast one attachment to proceed');
return false;
catch(e) { //For Service Portal
if(count <= 0) {
return false;
12-03-2020 07:17 AM
here if you see there is method getSCAttachmentCount() which has defined in UI Script, so make sure you have created ui script and then called in your catalog client script.
12-03-2020 07:24 AM
12-03-2020 07:26 AM
is it still giving error in console ?
12-03-2020 07:29 AM
Yes it was giving the same error
I have change the onsubmit script to this and it got worked..
Thank you very much for the help!!!
if(window == null){
// portal
return false;
else{
// native view
return false;
