Auto-Close Resolved Cases
Rob Sestito
Hello SN Comm,
So I have had help with this in the past, and believe I got a lot accomplished.. However, I believe I missed an important piece and overlooked what I should have really done.
The OOB Incident Autoclose looks like this:
autoCloseIncidents();
function autoCloseIncidents() {
var ps = gs.getProperty('glide.ui.autoclose.time');
var pn = parseInt(ps);
var queryTime = new GlideDateTime();
queryTime.addDaysUTC(-pn);
if (pn > 0) {
gr.addQuery('incident_state', IncidentState.RESOLVED);
gr.addQuery('sys_updated_on', '<', queryTime);
while(gr.next()) {
gr.incident_state = IncidentState.CLOSED;
//   gr.comments = 'Incident automatically closed after ' + pn + ' days in the Resolved state.';
gr.active = false;
gr.closed_by = gr.resolved_by;
gr.update();
I was informed to correct this by adjusting accordingly.. as I need this to happen to HR Cases.. we do not use Incidents..
so I adjusted like so:
autoCloseHR_Cases();
function autoCloseHR_Cases() {
if (pn > 0) {
var gr = new GlideRecord('hr_case');
gr.addQuery('hr_case_state', HR_Case_State.RESOLVED);
while(gr.next()) {
gr.hr_case_state = HR_Case.CLOSED;
gr.active = false;
gr.update();
Does this seem correct or completely wrong?
Anyone able to help thank you!!
-Rob
HI Robert,
If you are going to employ a schedule (to skip over weekends) and wait a certain number of days after then you'll need a scripted solution. The scriptless solution was designed to work with simple use cases of "if these records are found, then set these values on them." You've stated a more complex set of query parameters.
At this time I'm not available to create that solution for you. Apologies.
If you do not currently have talent in house to develop this, I recommend engaging with professional services from ServiceNow or one of our partners.
PartnerNow | Sales, Services, Technology Partners | ServiceNow
25 REPLIES 25
I was just going to say, it's in the description of the update set as well.
***IMPORTANT*** AFTER COMMITTING THIS UPDATE SET, Navigate to System Definition> Fix Scripts and run Update Scheduled Jobs
Now Chuck, I must keep asking.. And I hope that is okay!
Along with the Business Rule we went over, how I was looking to change the Incident Auto-close to HR Case Auto-Close. I also have a Scheduled Job created, which is: auto-close resolved HR cases, with the script as:
// Close incidents after 5 business days
var days = -5;
// Business days exclude Saturday and Sunday
var day = new GlideDateTime(gs.nowDateTime());
var weekday = day.getDayOfWeek();
days = days - 2;
day.addDays(days);
// Find resolved incidents
gs.log('SJ Auto-close hr cases looking for cases resolved before ' + day.getDisplayValue());
var hr_case = new GlideRecord('hr_case');
hr_case.addQuery('state', '20');
hr_case.addQuery('sys_updated_on', '<=', day);
hr_case.query();
while (hr_case.next()) {
gs.log('SJ Auto-close cases found resolved case ' + hr_case.number + '. Was updated on ' + hr_case.sys_updated_on);
hr_case.state = '3';
hr_case.update();
Does that change anything we just discussed? (and did)
-Rob
Hi Robert,
You can replace the HR Case Auto Close scheduled job with one you build using the scriptless solution you just added. Something as simple as:
Table: HR Case
Condition: State | is | (whatever) AND Updated | at or before | 2 | days ago
Action:
Set field values:
State | is | Closed
I just thought of something... you may need to run the scheduled job as someone who has application admin rights to the HR app. Normally scheduled jobs run as "system". Since HR is protected with application admin rights, this may not work. Test first, then let me know and I can guide you through the "Run as" feature.
I have admin to everything within our Instances and security admin - are you speaking to that or is there something deeper I'd have to look into?
-Rob
Yes, HR is a protected application with something added fairly recently called "Application Administration". Think of it like "Elevated access" (e.g. security_admin) only for an entire application. It's how we protect sensitive information like HR stuff from even people with "admin" rights. You effectively set an application specific 'admin' person to be the admin of that app - not necessarily someone with the admin role, but they DO need admin role to add on.
Application administration
