Auto create a problem if Major incident is resolved
12-11-2025 08:16 PM
Hello Everybody,
The requirement is when a Major incident is resolved then automatically a Problem ticket.
I created a BR to implement this but it is working sometime and sometimes not working.
Please check the below script and let me know if any changes needed.
I installed the Major Incident Management Plugin also.
One more thing is do i need to use Major Incident Management application scope or Global scope also fine?
BR Script: After Update
12-11-2025 10:29 PM
12-12-2025 06:48 AM
Hi @sattar3 ,
Why? This is in general not best practice according to ITIL? The reason that I'm stating this is, that a problem record should be open only if an incident is solved by a workaround either without a permanent solution, or where a permanent solution is differed due to other reason.
