‎07-27-2020 10:02 PM
‎07-27-2020 10:19 PM
Do you have attachments in record? --use include attachment checkbox in Notification
If you dont have attachment in record and want to send image. Use email script.
// insert the image to image table
var image = "abc.png''; //image name
template.print( '<img src="' + image + '" />' );
//call the email script to youre Notification using
${mail_script:emailscriptname}
‎07-27-2020 10:38 PM
Hi Ganesh,
Using email script you can attach images
var image = '';
if( /*condition*/ )
image = 'image1.png';
else
image = 'image2.png';
‎07-27-2020 10:40 PM
Hi Ganesh
Please refer below links, it has solution of you question with step by step screenshot go on this link and see all reply of Jim Coyne
Hope this will be useful for you.
Kindly mark it correct and helpful if it solves your issue.
Thanks and Regards,
Anish kumar
‎07-27-2020 11:00 PM
Hey Ganesh,
To attach screenshots or Image to notifications:
Follow the Screenshots:
Step1: There is Icon Insert image on the notification-->click
Step 2: There are two types:
Image Library: you can select image from db_image table.
Attachment: From you folder.
Select Attachment.
Step3:
Select the name of image or screenshot-->Adjust other parameters according to your need-->Save
Click on preview notification to see result:
Output:
Mark Correct and Helpful if it helps!!!
Best Regards,
Namrata.
