Cancelling transaction Script include not working
Hi Team,
i am trying to populate some field value from a User record via On Change catalog client script and getting this message in logs
Cancelling transaction #67630 /angular.do (cancelled by other transaction) angular.do?sysparm_cancelable=true&sysparm_type=sp_ref_list_data
@Anurag Tripathi : i checked again found that i was passing the name of method/function wrongly - resolved now
thanks
hi @Anurag Tripathi , i just posted above
Lets narrow down the issue step by step
firstly, please add a ,on on the script incldue and print ID (parameter value being passed from client)
And remove Json, just return a simple single value on the client and alert it on client.
this way we will check whether the call is complete and you are able to get to user record or not.
i initially did same
alerts provided response and its confirmed that its taking value from ref_requester and alerting it but
when it makes call to script include it doesnt print in log anything like sys_id of user or name of user / manager and doesnt alert anything in catalog client script rather shows JAVASCRIPT BROWSER ERROR
let me run for one value and try without JSON and revert back
same is happening this time also
In native UI also same happening
var MWNUserUtils = Class.create();
MWNUserUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
	getUserDetails: function(){
		var id = this.getParameter("sysparm_id");
		gs.log('ankit-' + id);
		var gr = new GlideRecord("sys_user");
		gr.get(id);
		if (gr.next()) {
			//var dataArray={"manager": gr.getValue('manager'), "location": gr.getValue('location'), "department": gr.getValue('department') };
			//return JSON.stringify(dataArray);
			gs.log('ankit-'+gr.getDisplayValue('manager'));
			return gr.getValue('manager');
	type: 'MWNUserUtils'
	alert(g_form.getValue('ref_requester') );
   var ajax = new GlideAjax('MWNUserUtils');
	ajax.addParam('sysparm_name', getUserDetails);
	ajax.addParam('sysparm_id',g_form.getValue('ref_requester') );
	ajax.getXML(getResponse);
	function getResponse(response){
		/*var obj= JSON.parse(answer);
		alert("response: " + obj.manager);
		g_form.setValue('ref_location', obj.location);
		g_form.setValue('ref_business_unit', obj.department);
		g_form.setValue('ref_reporting_to', obj.manager);*/
		alert(answer);
		g_form.setValue('ref_reporting_to', answer);
