Comparing List Collector Values with another variable, if it matches show alert
Nasir1
Sorry it might be a noob question but I have catalog item that has a list collector (employee_current_roles) which auto-populates user's roles with all the roles user is member of, I have another variable (role) on the form that is reference field and users can pick up any roles and log the request.
What I want to do is If any of the roles in list collector matches the value in referenced field I want a pop up to say User is already member of the role but I am not sure if what I am doing is correct, please help.
    var urole = g_form.getValue('role');
    var gr = g_form.getValue('employee_current_roles'); //  getting the List Collector Variable value
    var ar = gr.split(','); // split the list collector by comma
    for (var i = 0; i < ar.length; i++);
    if (ar.indexOf(urole) == -1) //if field values are the same then send alert
        alert('User is already Member of the Selected role');
        g_form.clearValue('role');
That's strange issue,
Can you try adding below alert to see what values those variables are storing:
	if (gr.indexOf(urole) > -1) //if field values are the same then send alert
                alert("gr value :"+gr+" urole : "+urole);
with new alert you might understand the exact issue else show me the alert data you are getting so that I can help you further.
Let me know if you have any further queries.
Please mark this as Correct or Helpful if it helps.
Thanks and Regards,
Abhijit
Community Rising Star 2022
By marking my response as correct or helpful, you contribute to helping future readers with similar issues.
Abhijit
ServiceNow MVP
32 REPLIES 32
@Nasir
Can you share screenshot of your script, the whole form.
Best Regards
Aman Kumar
@Nasir
With all due respect, all of them have suggested the same thing and by taking their precious time and tried to help you but you have marked the same response which was shared with you much later.
Best Regards
Aman Kumar
@aman
Apologies mate honestly I can see now what I did wrong there, please take it as a noob mistake and will keep your feedback in mind for next time when I am marking correct Answer. I wish ServiceNow had an option to mark more than one correct answer and mark everyone who replied as champions :).
Again apologies for the rookie mistake!!
Murthy Ch
Hi Nasir,
Instead of writing a client script better you need to exclude the roles which are there in list collector.
Reference qualifier:
javascript: "sys_idNOT IN"+current.variables.variable_name; //list collector variable name
Hope it helps
Murthy
Murthy
Good Idea but I am using the same variable set in other categories on the same form, and requirement is to display the role for other categories as we are using those roles for employment types
