Create calculated field in servicenow
georgechen
Hi folks,
Just wondering if anyone can help with a calculated fields in ServiceNow,     In RDBMS system we can create alias fields to achieve this (e.g birthday time = getTime(dob)) , whereas in ServiceNow is there a feature to create a virtual field that is a based on a calculation e.g SLA = 2016-07-14 12:38:09, and SLA Date is 2016-07-14,
A potential solution is to make a Business rule to truncate the date but it will overwrite the field value.
Any advice would be appreciated.
Kind regards,
George
If you need to calculate fields in reporting, you can use Explore Analytics -- it doesn't require any javascript, and it can be defined per-report.
For example, if you need to pull a component of the Date-Time field:
Then you can have it in a column in a report like this:
Calculated Column
Or a graphical chart:
Calculated Column (Chart)
And you can do this across tables. The advantage of this approach is that you don't need an admin to set this up for reporting purposes; users can calculate that in-report the way they might in an Excel formula (only automated).
