Difference between OrderNow (Service Catalog) and Submit Button(Service Portal)?
kutvaram
May I know what is the difference between "Order Now" Button in Service Catalog (Normal View) compared to the "Submit" button in Service Portal?
Because, I have a catalog client script written on onSubmit() of a form which is working correctly in normal view but not in the service portal.
Thoughts?
Thanks & Regards,
Ram Prakash
If you think this is the only way then you could try this dirty hack
var status = false;
//GlideAjaxCallHere
//CallBackFunction
function callBack(res){
//processResponse
status = true;
while(!status){}
//rest of the code here
Hi Gurpreet,
I am going to try that via Workflow.
Is that possible to create multiple RITM via Workflow based on the List Collector Value (number of selection in it)?
Thanks & Regards,
Ram Prakash
vintotz
have you configured the client script UI Type to All?
Yes it is already in "All" UI Type.
