07-08-2025 05:57 AM
Hello Community,
My requirement is to customize the Major Incident Management UI page that appears after clicking the 'View Workbench' UI action within a major incident record. I am attempting to call my custom UI page by overriding the Out-of-the-Box 'View Workbench' UI action, but I am encountering the following error.
Your help is much appreciated.
Linda
07-12-2025 12:11 AM
Removing $ sign from below syntax has fixed the issue. $ symbol is reserved for OOTB system UI pages, hence it should not be used for custom UI pages. var url = "/$<ui_page_endpoint>.do?sysparm_stack=no&sysparm_sys_id=" + g_form.getUniqueValue();
Linda
07-09-2025 05:14 AM
can you share the code of OOTB UI action?
also did you try calling the complete endpoint and not just name for the UI page?
07-09-2025 07:06 AM
@Ankur Bawiskar Here's screenshot of OOTB UI Action and UI Action script content
UI Action Script -
07-09-2025 07:08 AM
Here's Custom UI action screenshot and UI action script -
Script -
07-09-2025 07:16 AM
the issue is your UI action is not able to invoke that UI page.
did you try calling the complete name?
07-09-2025 08:07 AM
I am trying to call the UI page using the complete endpoint URL and the UI page name, but nothing is working.
When examining the OOTB UI action, I see it's calling the UI page as:
var url = "/$major_incident_workbench.do?sysparm_stack=no&sysparm_sys_id=" + g_form.getUniqueValue();
What's confusing is that the OOTB UI page doesn't have any attribute with the value "/$major_incident_workbench". Both the UI page name and endpoint attribute are completely different from what's being referenced. It's unclear where the system is getting the reference to "$major_incident_workbench".
Could you please do me a favor and try to copy the OOTB UI page in your PDI by renaming it, and see if you can call it through View Workbench?
